ksmoody's avatar
ksmoody
Propane inline Tee
I would like to install a brass propane tee on my rig between the tank and the regulator to connect a BBQ.
I don't know what type of thread connection to get. I have seen ones that are POL or ACME thread. I don't know the difference between those two types.
I have a 2008 Fleetwood Tioga.
  • pnichols wrote:
    It must be that your RV's built-in propane tank is on the same side as the awning so that you can BBQ where all the outside activity is?
    Our propane tank isn't on that side, so we have to carry along separate tanks for the BBQ and fire pit so that we can use them around the awning area.
    with the 25 foot line I hook it to the tank then toss it under the coach and have plenty of room to hook to the BBQ. My lines are always taped off to prevent debris from getting in them.
  • The first thing you need to do is to split the line where you want to install your T so you can see what you need. If you pull the pipe on the upstream end of your regulator, it's probably a 1/2" pipe thread. If you pull the connection from between your propane tank shutoff valve and the pipe to the regulator, it MAY be a pipe thread or it may be a propane spud or even an inverted flare fitting. It all depends on how your manufacturer put it together. Once you get it split you'll be able to tell. All possible fittings should be available in a good hardware store, auto supply store or at a propane dealer.
    We've done what you want to do, but mine is set up to feed propane from a 5 gal BBQ type bottle to the rig so I don't have to pack the rig up to go into town when I need propane. Just be sure you put a propane valve just downstream of your new T to the BBQ. That way if your hose springs a leak, it can be isolated from your rig propane system.
  • It must be that your RV's built-in propane tank is on the same side as the awning so that you can BBQ where all the outside activity is?
    Our propane tank isn't on that side, so we have to carry along separate tanks for the BBQ and firepit so that we can use them around the awning area.
  • I had my local propane dealer make me one and a 25 foot hose. It works well. When finished I turn the fuel off at the tank and let the remaining fuel burn off before disconnecting. I stored my line in the compartment in the rear of the coach and the odor of the fuel is evident each time I open the compartment door. I even taped over the ends before I put it inside to prevent any dirt or spider contamination that would clog the hose. I have the BBQ stored under the dinette but that hasn't been an issue. Maybe because the BBQ is in a plastic bag?
