dougrainer
Nov 13, 2020Nomad
WHERE did you read not to use Dextron 3. Motorhome Hydraulic Jack/slide systems ALL use Dextron 3. From the Kwikee owners manual. Doug
1. Be sure the leveling jacks are in the retracted position. Remove the breather cap
on the reservoir and check the fluid level in the reservoir. The fluid level should be
approximately 1" below the top of the reservoir. This standard provides an adequate
amount of fluid for the levelers to operate efficiently. If the fluid is below this level, add a
sufficient amount to bring the level up to the operating standard. When filling the
reservoir, use transmission fluid only. We recommend Dextron III. Do not mix fluids.
