dougrainer
Nov 13, 2020Nomad
navigator2346 wrote:
"Motorhome Hydraulic Jack/slide systems ALL use Dextron 3"
Not ALL systems use what you mention. Some use a different hydraulic oil including mine. Besides, there is no such thing as "Dextron"; it is Dexron.
The Dexron fluid can be used but it will discolor anything it touches red. That is why some systems, including mine,use a colorless hydraulic fluid. Probably the same composition but who knows
Sorry about the t. Dexron has a red dye. HWH fluid is Dexron 3 without the red dye. State what system you have that does NOT use Dexron 3. System and what fluid is recommended. Doug
38,782 PostsLatest Activity: Sep 10, 2026
