Dale_Traveling
Jul 27, 2016Explorer II
wolfe10 wrote:
Bottom line: It takes XX HP to climb a grade. If you generate that HP at 2000 RPM instead of 1600 RPM, the FAN and WATER PUMP are turning 400 TIMES A MINUTE FASTER.
Works the same for a gas coach also. Down shift and get the RPM up. It's not a race to the top and if it is you're using the wrong vehicle to win the race.
38,766 PostsLatest Activity: Jan 10, 2026
