JCatExplorer IIIJul 27, 2016Proper Shifting to Reduce Engine TemperatureI have had my RV for 12 years and I think I learned something new. From the very first month I had the RV I experienced overheating when traveling in temps over 100 degrees outside. I have a CAT C...Show More
tinkererExplorerJul 27, 2016That is exactly the same thing I do when climbing that same grade. I like to keep the rpms at 2000 or above. This also a C7 Cat.
Related ContentShift! **** You Shift!Schwintek slide jammed - shifted backshifting on downhillsWindshield shiftedProper outside storage
