J-Rooster
Jul 28, 2016Explorer
hipower wrote:J-Cat, glad to hear that your really learning about your CAT Motor and what it takes to get it running good. Highpower, those were the good old days! Keeping those diesel motors right on 2150 RPM's and if you shifted into neutral with the Jake Brake on it would kill the motor! My boss perfered us to take our foot off the throttle when the pyro got to 1000.
Those of us who have some trucking experience in our backgrounds drove when pyrometers were prevalent. Measuring your exhaust temperature was almost a neccesity to keep from cracking a piston or exhaust manifold in the early days of turbocharging OTR diesels.
I don't recall the exact temps suggested but they were different depending on the probe placement, pre or post turbo. Somewhere in the dark recesses of my mind I think it was 1200 degrees pre turbo and 800 degrees post turbo, but I can't swear that is correct anymore.
The key here is that if your EGT was too high you downshifted a gear and backed off on the throttle to keep the EGT in an acceptable range. Using our coolant temps to guide us is just a less accurate way of doing the same thing.
Bottom line, if you experience temps that make you uncomfortable while climbing a grade downshift and reduce throttle input to bring the temps back down.
38,766 PostsLatest Activity: Jan 10, 2026
