time2roll
May 26, 2015Nomad
bshpilot wrote:Is the OP plugged in?jerseyjim wrote:
The coach batteries MUST be "ON". To power the 12V control panel that controls the fridge.
NOT on our coach - i can turn the batteries OFF & the converter Charger will power everything thats 12vdc...including the fridge.
the converter charger (run via the generator or shore power) will create 12vdc & there for power the fridge (and any other 12v dc appliance or light).
Why would you have the battery off if you are plugged in?
Since the OP was priming with propane I had assumed it was NOT plugged in. Don't even need propane if plugged in.
38,782 PostsLatest Activity: Sep 10, 2026
