Noticed that PVC line between grey tank and drain valve has hair line crack in it. Is the a way to fix it without having to replace the pipe? Maybe with JD Weld for PVC & Plastic?? Thank you
It's ABS pipe. How long is the crack? You can replace the section with two couplers and straight section of the same size pipe. Or you can use a rubber union that has hose clamps if the crack is shorter. Or if it's really short you can just use several layers of ABS cement to fill it in.
