pappaoneExplorerJun 18, 2014PVC pipe has crackNoticed that PVC line between grey tank and drain valve has hair line crack in it. Is the a way to fix it without having to replace the pipe? Maybe with JD Weld for PVC & Plastic?? Thank youShow More
Carvin_MarvinExplorerJun 19, 2014There is a repair that is made of two halves that you glue over the crack area. It may never leak as there is only gravity pressure.
Related Contentmaking a pvc sewer pipePVC Vent Pipe Mod QuestionPVC roof failurePVC Pipe Solvent/Cement, How do you Prolong in storage ?Do holding tank weathervanes glue to standard PVC pipe?
