pappaoneExplorerJun 18, 2014PVC pipe has crackNoticed that PVC line between grey tank and drain valve has hair line crack in it. Is the a way to fix it without having to replace the pipe? Maybe with JD Weld for PVC & Plastic?? Thank youShow More
valhalla360NavigatorJun 19, 2014Fixed ours 5 yrs ago with epoxy left over from a boat project and some fiberglass cloth. Since it's under the trailer, I didn't bother with looks. Just wrapped the cloth around a couple times and then wet out the cloth with the epoxy.
Related Contentmaking a pvc sewer pipePVC Vent Pipe Mod QuestionPVC roof failurePVC Pipe Solvent/Cement, How do you Prolong in storage ?Do holding tank weathervanes glue to standard PVC pipe?
