pappaoneExplorerJun 18, 2014PVC pipe has crackNoticed that PVC line between grey tank and drain valve has hair line crack in it. Is the a way to fix it without having to replace the pipe? Maybe with JD Weld for PVC & Plastic?? Thank youShow More
gatorcqExplorerJun 19, 2014If it is a crack, drill a small hole at the end and beginning of the crack to prevent is from spreading longer
Related Contentmaking a pvc sewer pipePVC Vent Pipe Mod QuestionPVC roof failurePVC Pipe Solvent/Cement, How do you Prolong in storage ?Do holding tank weathervanes glue to standard PVC pipe?
