pappaoneExplorerJun 18, 2014PVC pipe has crackNoticed that PVC line between grey tank and drain valve has hair line crack in it. Is the a way to fix it without having to replace the pipe? Maybe with JD Weld for PVC & Plastic?? Thank youShow More
pappaoneExplorerJun 19, 2014Thank you for all the excellent suggestions.The crack isn't big enough to warrant replacing the pipe, so will try using ABC cement or some epoxy.
Related Contentmaking a pvc sewer pipePVC Vent Pipe Mod QuestionPVC roof failurePVC Pipe Solvent/Cement, How do you Prolong in storage ?Do holding tank weathervanes glue to standard PVC pipe?
