Goldencrazy
Jul 08, 2014Explorer
Not sure the age of your motorhome and hence your system but if older it may not be digital. If it is digital then you must select antenna as input and then do channel search. Assumed you have turned on amplifier as previously mentioned for the antenna. I have a suspicion because of blue blank screen you have an older CRT and no digital box. Also assume you have cranked up antenna and not a sat dish. Please provide the details on your coach.
