kgarrett9999
Jul 09, 2014Explorer
compint wrote:
Thanks for the responses. We do not have a dish network setup. I will walk through the steps tomorrow to see if I can get it going. I am not sure exactly how to align it with the different stations but will give it a try and keep you posted.
Thank you,
I use an android app called "TV Antenna Helper" to find the local stations wherever I'm at. It displays them on a map or compass color coded to strength/distance.
If your antenna is like most that I've seen, you simply pull down on the ring around the crank arm and turn the pointer to the desired direction. Turn it back before lowering the antenna.
