Gator48
Jul 09, 2014Explorer
There is a very good chance your TV is not digital compatable. You will probably need to get a digital converter from Best Buy or Radio Shack and place it in line between the antenna cable and the Winegard switch box. You will then need to use the converter remote to change channels and leave the TV set on either CH 3 or 4 as per the converter instructions. Also the aiming of the antenna is critical as the digital signal is pretty much either hitting the antenna or not. No in between.
Good excuse to upgrade to a new HD flat screen for the to go house.
