wa8yxm
Jul 10, 2014Explorer III
If by a Winegard entainerment center you are refering to a box of many buttons.. Then I have the same thing.
First: IF you plan on over the air TV, you must have modern TVs or, digital converters... You will need to understand how to get to the signal strength meter.
Now, for each TV, you wish to watch make sure the ANT button is pressed, this assumes you want over the air, Cable/Sat instructions follow.
THe POWER BUTTON on the left must be pressed, and the Light must be on., If that is there is a LED.. that power switch is likely your downfall.
Crank up the antenna use the Antenna Helper app to aim (Remember the arrow on the dial is 90 degrees clockwise of the antenna)
On the TV SCAN FOR CHANNELS. Then go to signal strength and peak by turning the antenna slightly.
That should do it.
For cable or Sat (or dvr/vcr) press the proper buttons on the selector.
DVD also requires the power be on for the selector.
That should do it.
