jswatzell
Nov 19, 2015Explorer
Questions on Discovery motorhome
Hello
My son recently bought a Fleetwood Discovery Motorhome. The kicker is he is brand new to RV'ing so I have been trying to help as much as I can. However, there's a lot I'm not sure about when it comes to this type of RV. So I want to run a couple of things by y'all to make sure I'm telling him right. First off, he is full timeing in it. He works as a pipefitter so has to go where the job is. So this motorhome seems to fit the bill for him. Now for the questions. He has 2 heat pumps and 2 lp furnaces. I think probably the heat pumps work well down to a certain temp and then the gas furnaces kick in to supplement the heat pumps. Is this correct? We live in East Tenn so we get some cold weather but not super severe usually. One thing I'm not sure about is how do the water lines fare in cold weather? I think as long as the gas furnace is running the lines will be fine as they are in a heated area under the floor. If only the heat pumps are heating the home then the gas furnaces wouldn't be heating the area under the home to keep water lines free. However if I'm thinking right the lp furnaces would be running if it gets down cold enough to freeze the lines. Am I thinking right?
Is there any other thing he needs to do to prevent cold weather problems? He is getting a heated water hose to prevent that from freezing and has a frost proof faucet supply. Thanks for the help in advance.
