Vic65's avatar
Vic65
Quick Question on Dico sealant
Hello I was checking the dicor sealant on my roof. I noticed that there is some type of plastic shell over the dicor. The plastic shell is coming up. When I removed the the plastic shell the dicor under the shell is white and soft and looks to be in good shape.
My question is do i remove the plastic shell and more dicor to the area that need it. and is this plastic shell part of the dicor.
  • Looks to me that that prior owner put silicone over the prior sealant I removed removed the shell and put more dicor over it.
  • Plastic shell isn't related to Dicor. Can you take a pic and post it? I don't know what it could be.
  • Dicor gets a hard outer surface as it cures. If I find a crack in that outer surface. I clean the area and put a fresh layer of Dicor over the crack.
