My steps worked fine all day, got to the camp site and get 2 clicks when I open or close the door, any quick hints to diagnose the problem or should I pick up some plastic steps for the rest of the tr...
Linkage could be broken. Look under the step or try to move step physically. How loud is the click? It could be a relay in control box. This could indicate with no movement a bad motor, no power to step motor. Check the two ground connections under the step. Stay clear of step while doing any inspection or work as it could attack you. Check fuses. should be two. one control and one power.
