My steps worked fine all day, got to the camp site and get 2 clicks when I open or close the door, any quick hints to diagnose the problem or should I pick up some plastic steps for the rest of the tr...
IF the underside amber step light goes on and off when you open and close the door, the Magnet is OK and there is power to the step. While opening and closing the door(activating the magnet) HIT the motor with a hammer. IF the step then operates, replace the motor. It is bad and will stick again. It has a bad spot on the Armature. Doug
