rgatijnet1
Nov 16, 2017Explorer III
As mentioned, you can set up multiple waypoints for your garage sale locations and enter "shortest route" BUT, this is OK if you use your toad ONLY. In your coach, using the shortest route mode, the GPS may send you down roads where your coach might not fit.
Once you use the GPS to show the route, you can adjust the waypoint order to make the most sense.
