Mighty_Thor
Aug 11, 2014Explorer
If it is blowing the Switch fuse it is probably an issue between the switch and the fuse block. Most of the rest of the items are fused separately and you should be blowing the individual fuses long before you blow a 60 amp fuse. I think one of the previous poster suggested that you pull the switch and test the lines to determine which one has the bad leg. You may have to trace a couple of junctions if it off your accessory leg. I have had similar issues with various vehicles over the years and most turned out to be a pinched or abraded wire under the dash, several but not all were steering column pinches.
38,769 PostsLatest Activity: Apr 24, 2002
