Ac engine compressor went out, will this cause debris in the hoses and the dryer? Has anyone had this problem and is it a big ticket item to fix? Thanks for any info
Clarification of compressor issue: I had the compressor and belt replaced, the pulley seized up causing the belt to break. Hoses are corroded and need to be replaced. Question is has anyone had this issue and did you replace the hoses?Also Is having the hoses replaced a high ticket item? Thanks to everyone who have responded
