Specs for Libero. 25 foot long, under 10 foot clearance. Very close to some models of the TrailLite. Say the 235? Comes with a Macerator pump, which I would have liked on my Trail Lite. Could dump into a PortaPotty with that!
Freedom II Libero Specs - 177" Wheel Base
Int. Height 75" (6'3") 1.9 m Rear Bed (Matress) 55" x 82"
Int. Width @ floor 89" (7'5") 2.3 m Converted Front Bed 78" x 49"
Ext. Width @ Running Boards 96" (8') 2.4 m Towing Capacity 5,000 lbs
Ext. Height with A/C 117" (9'9") 3.0 m Rear Axle Ratio 4"10
Ext. Length 300" (25') 7.6 m Fuel Tank 33 US Gallons
Dry Weight Approx. 10,000 lbs 4535 kg Brakes 4-wheel disk w/ABS
GVWR 12,300 lbs 5579 kg Air Bags Passanger and Driver
Engine Vortec 6.0 Liter V* Gas Engine
Horse Power 300 @ 4400 rpm
Torque 360 ft lt ft @ 4000 rpm
Transmission Hydra Matic heavy-duty 4 speed overdrive automatic with Tow/Haul mode
LEISURE SPECS
Fresh Water Tank 53 US Gallons 183 Liters
Grey Water Tank 30 US Gallons 113 Liters
Black Water Tank 29 US Gallons 110 Liters
Hot Water Tank (Propane/110v) 6 US Gallons 22.7 Liters
Box Awning 11'6"
Propane Tank w/electric shut off 57 lbs
Generator 4KW Gas Onan
Furnace 16,000 BTU Ducted
Air Conditioner 13,000 BTU Ducted Dometic with Heat Strip
FEATURES
Macerator pump
No isolator automatic solenoid shut off for auxiliary battery
Water Expansion lines w/ low point drain
WARRANTY
LTV 3 years / 36,000 miles or 60,000 kilometers
Chevrolet Base Vehicle 3 years / 36,000 miles or 60,000 kilometers
Appliances Covered by the individual warranties offered by their respecive manufacturers
