1999 Gulfstream/Sunsport 8325
Problem/No running lights
Where/ I 95 Sothbound/ Richmond VA
Which meant I couldn't run at night
I took the light switch out, which controls the running lights, which by the way was after I checked all fuses. On the back of the dimmer swith I took a paper clip and crossed jump two connections to give me running lights. I know that's a no no, but you have to do whatever it takes when you're out there. I did keep a very close eye on it and it was find until I got home and found the real problem. Which was a blown fuse I overlooked under the hood. They have two fueses under there both marked number six for running lights, I didn't know that at the time.
