cwdavis... I know this too late to do you any good, but you could have stopped the leak if you could have seen the hole. just take a bar of soap, any kind and rub it into the hole it,ll stop the leak for hours and even while going down the highway, we used to use this method to seal off leaks in our gasoline tankers that would develop a leak to get us safely off the highway and unloaded before repairing it, I hope someone can benifit from this as that is a miserable and dangerous position to be caught in, you could have been injured very bad if the product runs over and gasoline is even a worse fire hasard and while fighting the leak you get wet from it and it,ll burn your skin just from being wet. This is not a repair but it could by you some time to find the right repairs with out having to let some one that knows you are in a bind and charge 3 prices....Haaapppy Holidays....
