Thanks for the input. I was in error. I rechecked my notes I took from everyone that has been here and worked on things. 195 was the reading on one side and I do not know the reading on the other side. The transfer switch was replaced on the same day as the insides of the power pedestal. We are trying to figure out when we plugged into the neighbor's power why if there was a problem with our rv power things worked when plugged into another pedestal. The two converters that failed in the last few days we are just wondering what the chances of two next door to each other and one door down from us failing at the same time are. Just trying to figure it all out and understand the cause. Since we have a new transfer switch and a new converter is there anything else we should check or do to prevent future electrical problems? All GFI's are new. Wiring has been checked and triple checked by electricians. That is part of what is confusing the park electrician checked our RV and said everything was ok. That was after the rv techs checked and said it was all ok. The park had 3 electricians from same company over several weeks and they all checked everything and took it all apart and could find no problems in rv or pedestal. Thanks so much for all of your help.
