willald
Oct 26, 2023Explorer II
Lantley wrote:
I would assume rig was not quite level as a result the slideout was somewhat racked and would not extend fully. Once the rig is leveled properly the issue goes away.
Yeah, I think this pretty well sums up what happened. Crazy thing is we've been camping with this particular rig a LOT for over 2 years, sometimes in very remote, unlevel (to put it mildly) campsites, and this was never an issue until now.
The takeaway is avoid the really unlevel spots when possible. Pull up on boards to get closer to level or do whatever you can if you encounter a really unlevel site. Know that the slideout will not extend properly on a really unlevel site.
Agreed, thats definitely the lesson learned from this.
I've found over the years, that the best sites with the best views, access, etc. are usually the ones that are the most unlevel. Sooo, I carry a lot of blocks for leveling, and usually don't mind using them and taking the time to get it leveled even on the most unlevel sites (been on sites muuuuuch worse than the one we were on this last weekend). This was one time, though, I got lazy and in a hurry, and paid the price, haha. Hopefully won't happen again.
Not quite the same but I don't like it when the auto level function raises my 5'ers wheels off the ground. I do what I can to avoid the wheel raising scenario
when I recognize a site is way out of level
I am the same way, Lantley! I will not let a wheel get off the ground. If site is that unlevel, I break out the big, long blocks I built for driving wheels up on, and will drive whichever side is low up onto the blocks. Then, will stack several blocks under each of the jacks so the jacks don't have to extend as far, either. I've found that the more blocks you use and the less you extend your jacks, generally the more stable things are inside.
Seen people lift wheels off the ground all the time, and I imagine the jacks will handle it and won't hurt anything. However, I don't like the lateral stability you lose when you do that. The tires need to be on the ground, to help with lateral stability.
Fortunately, Lantley, where we are going next week up in your neck of the woods, the site is very level (and beautiful!), so won't be a problem. Looking forward to meeting up with you. :)
Will
38,709 PostsLatest Activity: Mar 09, 2025
