Bob360
Sep 26, 2017Explorer
" I have an 83 chevy chassis, and the bottom of the gas tank has 2 plugs, one at each end, at a corner, that can be removed, to drain the tank"
This helps a ton thanks!!!
I was thinking about just getting it running for a couple years and when/ if the motor goes ill drop it and replace it then. I was looking at rebuilds and there only about 2-5k so if i can get some use out of it while i save to replace it would be best. At this point were only looking at weekend trips down the I5, basically where can we get on a full tank round trip.
STBRetired wrote:
If you want to keep it running well for a long time, you should pull the motor and do a full rebuild on it
38,720 PostsLatest Activity: May 13, 2025
