pconroy328
Mar 09, 2017Explorer
Re: HD View 360 Antenna System
Not sure if this helps - but the manual is here: http://manuals.solidsignal.com/HDMS9100_Manual.pdf
Problem: LCD displays Er
Possible Causes:
The position feedback wire (black) is not connected.
The coaxial cable is not connected.
The 3 control wires (red, black, blue) are reversed.
Possible Solutions:
Connect the wire*
Connect the cable*
Correct the wire connection*
* The receiver should be power reset after fixing the wire connection.
Possible Causes:
Possible Solutions:
Connect the wire*
Connect the cable*
