Mr__Jeff
Feb 17, 2014Explorer
Yes! Check your your MH slide configuration. Slides on carpet typically have steel rollers while slides operating on tile or laminate typically use plastic rollers. They can be changed for your new surface if they're steel. Some MH slide-out rollers are easier to change out if you need to change them.
Post your MH brand/model and others may reply with their experiences changing the flooring.
38,707 PostsLatest Activity: Feb 18, 2025
