jspringator
Sep 21, 2021Explorer
Well, the decision was made for me. West Marine did not have 5200 quick set, but did have 4200 quick set, so I used 4200. I did all of the pasenger side roof that lifted off, but my inspection revealed that the Eternabond remaining does not have a good bond. I will have to do the rest of the roof before too much longer.
The hardest part of the job was dealing with the Eternabond I installed 7 years ago. I would recommend that anybody dealing with roof issues is to go on and reseal it rather than try to seal it with Eternabond. It sealed fine to the roof, but did not seal to the J channel. It is easier to inspect the seal and re-seal it rather to cover up the joint with Eternabond I used lacquer thinner instead of mineral spirits. My experience is that lacquer thinner will promote better adhesion,
Once I finish the entire job, I will probably use a cosmetic strip of Eternabond to cover up all the Eternabond adhesive stain that is cosmetically unappealing. I will not attempt to go over the j channel.
