grldst wrote:
Easy fix and a heck of a lot cheaper then buying a new one. I replaced mine some yrs back, don't remember the exact procedure, but I do remember I did NOT have to remove the microwave, and it was not difficult.
My foggy mind seems to recall that you remove the facial plate around the door and you will get access to the bolts/screws to remove the door.
You should be able to google for parts, and you tube may even have a video on the repair.
ON EDIT: My memory has recollected that when the facial is removed you will see the door latch workings. The door does not have to be removed. Its a cheap plastic latch that breaks. I tried glueing it and it didn't last long, so I just replaced it. Like I stated earlier, the parts are cheap, the fix easy.
thanks. on the move for a couple days. Will try to get into it once we get settled.
