We installed one in our 2001 Adventurer and ordered one from the factory in our 2013 Adventurer. In the 2001 I centered it over the bed in the bedroom. No additional bracing was required, and power was extended from the original 12 volt overhead light.
The original light had a switch on the wall so I replaced the light with one that had a built in switch. The switch on the wall would put power to both units and the light could be turned on independently from the built in switch.
Be sure to locate the fan so that it can be run with the slides in ( our 2001 didn't have a slide) and the cabinet doors can be opened without interfering.
I would also suggest getting one with a remote control rather than a pull chain. That way the fan can be turned on or off and speeds can be changed without getting out of bed. It will also minimize strain on the mounts induced by constantly pulling on a chain.
I installed the fan in our 2001 in early 2002. We put over 12 years and 110,000 miles on the unit before trading it in on the 2013. It was still quiet and working fine when the motorhome was traded in.
38,707 PostsLatest Activity: Feb 20, 2025
