Effy
Feb 01, 2016Explorer II
Wiper blade replacement
I read somewhere a while back that instead of paying $30-40 each for wiper blade replacements that NAPA can replace just the rubber part on the existing hardware. Is this true?
Ava wrote:
I put two 28" blades from Costco for about $25 on my rig. The wider arms on mine also have two screws to secure the blade to the arm. With the new blades I popped out the rivet in the center of the new blades then attached the original mounting bracket with a small stainless nylock nut and bolt.
Works great and much cheaper.
