rgatijnet1
Aug 31, 2018Explorer III
All of the switches should be wired in parallel. Since you have voltage to the switch at the generator, then the issue should be the 12 volt feed to the other two switches. Using a voltmeter you should measure power on one side of each switch. If you do not, then you need to trace back to where the power stops. There might be a fuse in the hot line that has blown. I would expect the power to both switches to be coming from the same 12 volt source.
38,782 PostsLatest Activity: Sep 10, 2026
