Geocritter's avatar
Geocritter
Remote tire pressure/heat monitors and theft
I’ve seen several of these tire pressure/heat monitors advertised here and it seems like a helluva good idea. I’m not a fear-based kind of guy, but a high speed blowout is worrisome for me. However, that said I’m wondering how often these tire monitors are stolen, at $50 each it could get pricey. Can one take them on and off without losing tire pressure? I envision putting them on before traveling and taking them off when I set up in a camp ground, though I suspect they could be stolen just as easily while in a rest area taking a rest. I also noted that internal ones are made, which would solve the theft problem. However, unless done with a tire replacement there’d be an installation expense. I don’t mean to be paranoid or cheap but I was financially devastated over the last few years and can’t afford something like this only to have some dirt-bag rip me off.
Steve
  • You sure come across as a fear based kind of guy. I really can't believe how much you folks are concerned about theft of RV specific items! Now if you were to camp at Hunts Point in NYC, I'd be concerned. But the vast majority of the places we go in this country, I don't think you should be concerned!
  • Since I was purchasing tires, I opted for the type that has internal sensors. They work great, are invisible and theft proof. Simply mount the sensor onto the rim with a long hose type clamp. Then mount the tire and balance as usual. The sensor and clamp weigh next to nothing so there is no need for extra balancing. I'm sure there are many good systems. The one I choose was Tire SafeGuard. You can mix the internal sensors with screw on for the toad if you wish. They also make an internal stem mounted sensor. If you have an all steel body vehicle such as mine, be sure to get the "N" type monitor as some of the others may not pick up the signals properly.
    http://tiresafeguard.com/
  • I have been using them since 2005 and have never had a problem with theft. You are basically dealing with the RV crowd and I think most of us respect other RV'ers things. Most autos come equipped with tire monitors so that takes most people out of the picture. If you steal the sender you still need the matching monitor which is the expensive part. I don't worry about it, life's to short.
  • I have had my TST tpms for a few years I leave mine on all the time. I have not hand any problem with the MH or tow. You need special wrench to remove them. I would be concern with air lost if you remove them every time you stop.
  • If you are concerned about theft, you could take them off when not towing (in storage, at campgrounds, etc.)
  • I use the TST on both the Motorhome and the Toad.
    They have locks.
    Don't worry about them, and they have been fine for over 1k towing.
  • someone would have to have the monitor in order to steal them. It is safe to say no one is going to steal tire pressure monitors.
  • Steve,
    Most tire sensors have an allen type wrench that can be used to tighten them on to the valve stem. This does not mean that a thief will not have an allen wrench, but it does slow things down. They also make "flow thru" sensors that do not have to be removed to add air and they have the usual screw on type sensors that must be removed to check and add air. I'm not sure that theft of TPMS sensors is a common occurrence.
