- Yankee_ClipperExplorerMy rig has an Onan Marquis Gold 7000, which is 7kW and 54 amps total.
Underway, I can run both A/C units and a TV for the Grandchildren.
I do have 30-amp shore power, so I wired in an extra box to accommodate the 20-amps needed to run the forward A/C at the same time. Mostly, I ask for a 50-amp site and use a splitter cable to run both 30-amp and 20-amp cords. Easy, breezy, sweetie. - Mile_HighExplorer
tropical36 wrote:
Going to make some assumptions here and that you have a 5.5KW genset capbable of delivering 45amps. It has two breakers with one being a 30amp and the other a 20amp, that only feed the rear ac.
Not all the 5500 Onans were 30A-20A HACR, some were 30A-30A.
- AllegroDNomad
If mine, I'd install a dual power adapter, that you can make up yourself with online instructions, doing a search. This will provide for a separate circuit for the other ac and should give you the extra power you need, especially if you have an EMS system to manage it better.
As for the genset, removing it, will kill every dollar you could possible expect, if you ever decide to sell, so just fix or replace the darn thing, with the same labor you're planning for a 50amp service.
He posted in his second post that he has a 7K. - tropical36Explorer II
highlife4me wrote:
Since I have a 96 class A with a 30 amp service but a 50 amp genset that would run both AC units. I would like to remove the generator and wire in a 50 amp shoreline so I can run everything. Does anyone see a problem doing this as long as the proper materials are used?
As for the genset, removing it, will kill every dollar you could possible expect, if you ever decide to sell, so just fix or replace the darn thing, with the same labor you're planning for a 50amp service. - Mile_HighExplorer
DrewE wrote:
OK, that makes sense I guess. I did have a 30A Montana with a 2nd AC option and it came with a 50A plug that fed the second circuit for the AC, but he rig was still 30A. It was 2003 so must have been the same approach. I did only have the 5500 gen. I guess I figured 7K was overkill, but as Dutch said, sounds like it was an option.Mile High wrote:
Something must not be factory - a 7K genset in a 30A rig? That is one waste of a generator.
It's a 7K generator because it powers the 30A supply plus an additional (separate) second air conditioner circuit. The motorhome is set up to only use one air conditioner on shore power, but can use both simultaneously with the generator running. This is (or at least was) not all that unusual of a setup, though it does have its obvious inconveniences and drawbacks.
So I do remember looking into making that Montana a true 50A, but it would have taken a new panel and pulling in some new circuits and after a while I figured it wasn't worth it and eventually traded. It may be worth it for a MH. The biggest thing to overcome is trying to get in some additional outlets to share the panel and that didn't look easy. - ppineExplorer IIII would call the manufacturer first and figure what they were thinking.
No reason to remove your gen set. Have someone that knows what they are doing help you decide your next move. Something is wrong with this picture if your description is accurate. - Dutch_12078Explorer III
Exactly... Our previous coach, a 1995 Coachmen with 30 amp, was also equipped with a Marquis 7000. If I had a choice, I'd rather have that one than the Emerald Plus 5500 I have now. The 7000 was very smooth and quiet running at just 1800 RPM instead of the 3600 RPM the 5500 runs at. - DrewEExplorer III
It's a 7K generator because it powers the 30A supply plus an additional (separate) second air conditioner circuit. The motorhome is set up to only use one air conditioner on shore power, but can use both simultaneously with the generator running. This is (or at least was) not all that unusual of a setup, though it does have its obvious inconveniences and drawbacks. - Mile_HighExplorerSomething must not be factory - a 7K genset in a 30A rig? That is one waste of a generator.
- Chris_BryantExplorer IIAs John said, a true 50 amp generator is 12,000 watts.
38,782 PostsLatest Activity: Sep 10, 2026
