jluke wrote:
I just tried to check the fluid level in the parking brake assembly on my 2000 F53 frame Holiday Rambler and could not break the bolt loose with my sockets. It is either frozen on there or I have become too old and feeble (my wife's explanation). Can I try my electric impact wrench on this or do I run the risk of shearing off the bolt head? Seems like such a samll thing to ask on here, but having suffered the consequences of my actions over the years, thought it prudent.
I'm assuming you're speaking of the oil fill/check plug in the parking brake assembly behind the transmission, correct? If so, I can't imagine that plug being that tight. But, if you say it is, well, then it must be.
I have one suggestion for you. If it's that tight, here's a procedure that's worked more than once for me but, it involves some tactics and, a bit of money.
I have a can of "Freeze" hanging around for various reasons. And, I have my handy propane torch for various plumbing needs. What I've done in the past with stubborn bolts, sensors and more is,
1. Heat the area immediately around the problem plug with your propane  torch. No need to be there for hours, just a couple of minutes will do the trick. Then, immediately put down the torch, and pickup your can of Freeze and spray the bolt head for about 3-4 seconds. What that does is shrink the bolt threads while they've been expanded on the parent side by the heat.
The bolt/plug should pop loose without too much issue.
Scott
