CG Dawson wrote:
Pogoil, I suspect maybe you did something wrong during your install like putting it over silicone. I put it on both end cap seams and around the skylight about 5 years ago and it is still stuck like it was put on yesterday.
I followed directions to a T.
Put it on a fiberglass seam front and back, no silicone, roof seams had never been sealed except from factory, used roller to apply pressure.
If you re-read my post the white tape separated from the gray sealant. That is tape failure not incorrect installation.
Been sealing RV. roofs for 25 years.
Pogoil.
