Geocritter
Feb 23, 2014Explorer
Removing gray water tank insulation
In the next month or so I need to replace my gray water tank because of a huge unrepairable crack in the bottom. The current 40 gallon tank is mounted so that it extends half ways into a heated underside storage compartment; however the front half of the tank extends out of the front of the storage compartment and is completely covered with a several inch thick layer of sprayed on polyurethane foam insulation. Has anyone replaced a tank where they had to dig a thick layer of foam insulation off the tank before it could be removed? Is there anything special I need to know before embarking on this task? Thanks in advance for any advice or insight on completing this project. Somehow I can't help but think it's going to be a nightmare, however I can't afford to have a pro do it for me.
Steve
Steve
