stallion143's avatar
stallion143
Replaced analog thermostat with a digital one
I did this mod on a previous motorhome. So when we traded in our Class C for a Class A, I knew I wanted to change out the original analog thermostat as soon as possible. It was a direct replacement of my old 6 wire Coleman Mach. (Model # 83303362) Even used the same screw holes. Only took about 15 minutes from start to finish. One of the BEST upgrades to do, in my humble opinion....
b
  • path1 wrote:
    Thanks for posting. On Amazon it says goes down to 33 degrees. That is what I need. Right now with my stock t-stat only goes down to 43ish I think.
    Thanks again.
    You are correct, it does go down to 33 degrees. Did I mention it was easy to change out?
  • Thanks for posting. On Amazon it says goes down to 33 degrees. That is what I need. Right now with my stock t-stat only goes down to 43ish I think.
    Thanks again.
  • Thanks for posting. That is on my list of Mods for this Spring.
