johncasey37ExplorerSep 19, 2017Replaced Starter, now, no 12V power at the dashI changed the starter. Then the problem started...Had the starter checked. I checked every fuse i could find. Wires look ok, peeled back heat shield to check. 2 fuse boxes under hood. One 12" metal bo...Show More
ScottGNomadSep 19, 2017If you didn't disconnect the battery you may have taken out a fusible link someplace.
Related ContentReplacement Lights for TTPower Pack Jump StarterAdding power outlets in slide with no wiringNewbie power questionJump starters
