johncasey37ExplorerSep 19, 2017Replaced Starter, now, no 12V power at the dashI changed the starter. Then the problem started...Had the starter checked. I checked every fuse i could find. Wires look ok, peeled back heat shield to check. 2 fuse boxes under hood. One 12" metal bo...Show More
johncasey37ExplorerSep 19, 2017Thank you all for the suggestions.I am going to look at it again, carefully.
Related ContentReplacement Lights for TTPower Pack Jump StarterAdding power outlets in slide with no wiringNewbie power questionJump starters
