Effy
Jul 01, 2015Explorer II
Replacement for Jensen Back up monitor
My MH has the Jensen RV212TB which has conveniently decided to take a dump about one year out of warranty. The screen starts to fade, freeze and then goes black. I have checked all wiring, reset about half a billion times, unplugged and let the capacitors deplete, and it works for a while and then starts failing again. Jensen won't replace it, they won't even fix them, it's a throw away item. I have read reviews of this unit and it's apparently junk and usually fails in 1-2 years. They have stopped making them. Does anyone know what a reasonable replacement would be for this unit? I did like that it had radio, cd, and aux input as well as the camera itself. I don't want to spend a lot of money (this unit apparently retailed for about $600-800). Unbelievable. Is there a plug and play unit that can be used? It has the 3 camera inputs but I turned off the mirror cams - they were distracting and I like to see how the car tracks behind the MH so I just use the rear cam. I don't need/want GPS either. Just a radio that allows me to use the existing wiring and camera(s).
Thanks
Thanks
