grumpy3b
Jul 30, 2019Explorer
still nursing mine along. Once the solar and batteries are upgraded I'm going with anything that has a high efficiency compressor. Will have over 5kWh battery power so one of the new high efficiency options won't really cost anything to run. I'm out west so sun is rarely an issue for more than a day or two likely enough battery power to cover around 4-6 days of marginal or no sun w/o needing the generator.
If i can fit a residential into the kitchen I will otherwise I'll go with the Amish high efficiency compressor upgrades. Watched a video and as long as you can, DIY retrofit is nit too fiddly.
