Gjac
Aug 01, 2019Explorer III
Those that report that your cooling units no longer worked, what was the issue? Were the tubes blocked or did they leak ammonia or something else? Also a thermometer that just measures air temps inside the refer will be higher each time your open the door a thermometer inside a glass of water will be a more accurate way to measure the actual temperature of the food.
