TimfmCT's avatar
TimfmCT
replacing a/c heatpump
Hi,
I've been on the group before about our Duo Therm a/c heat pump.
The heat pump was tripping the 20a breaker. Now that it is warm, see that the A/C seems to work ok.
Coach-Net located a service company to check it out. Turns out it was a residential/commercial outfit. The tech was very nice but hadn't worked on a RV before.
We ran the heat pump (it's warmer outside now)and it ran without tripping the breaker. He noted that started out with a normal current but as time went on it slowly increased to 17+amps.
His opinion was he didn't see any way to repair the unit and recommended that I have it replaced. He compared it to a housed window unit.
I've called around to try to determine exactly what unit I may need. The current unit is a DuoTherm 59136.531 E1.
Number one - are these units not repairable? He did say it was not the capacitor.
Number two - does anyone know the part number of a replacement a/c heat pump......... I've been waiting quite awhile to hear back from Camping world.
We are on theroad and It's awkward because I'm not convinced it needs to be replaced.
  • TimfmCT wrote:
    Hi,
    TimfmCT
    Unfortunately that's a common problem.... (to often CoachNet's "list of service providers" has little to do with the REAL WORLD).
    When I had an engine problem, CoachNet had my coach towed 50 miles to
    a Cat shop on their list that DID NOT WORK ON MOTOR HOMES!
    Another time, (when I had a Norcold refrigerator problem), CoachNet refereed me to a RV manufacturer on their LIST.
    When I got there it turned out that, (although they installed Norcolds in their new trailers and 5th wheels), they DID NOT REPAIR APPLIANCES!
    Those 2 experiences taught me the following:
    NEVER drive to, (or allow CoachNet tow your RV to), a service provider on CoachNet's "approved/recommended list", without phoning ahead to verify that the service provider can/willactually do the repair!
    Mel
    '96 Safari
  • People say many of these units are not repairable. However, with enough "engineering" almost anything can be repaired. I have one A/C that I had to "weld" in a R-134a port, vac it out, and refill.
    I know that doesn't answer your question, but I believe anything is a possibility.
