Dale_Traveling
Mar 12, 2014Explorer II
The soft rubber gasket on the filter will hold on to the cover a bit. Give it a whack with a mallet to break it loose. There are only the two clips on the front that you need to open. In the back are lips, kind of like a firewall mounted fuse box, the hold the back on. Once you get the front open an inch or so the rear surfaces will release.
38,782 PostsLatest Activity: Sep 20, 2026
