I am going to replace the carpet in my coach. I am going to take out the old carpet and use it for a template. Has anyone replaced carpet doing it this way ? How did it work out ?
The carpet you take out will lose its stectch.And if you use it as a template it will be short eveywhere.Carpeting around a everything is very tedious. A carpet installer would be your best bet. Call a local flooring distributor that sells supplies to only flooring guys and ask for reccomendations. If need help on anything I would be glad to help.
